TwinTurbo.NET: Nissan 300ZX forum - Pull the connector and clean it as well as check if the
Audioquest
on June 29, 2008 at 6:58 PM
Coolant temp gauge needle moves erratically.
posted by jkcizbck
on June 29, 2008 at 06:56 PM
tab on the sender is loose. Common problem the rivet that crimps it becomes loose. Carefully use a flat punch and tap it a bit to renew the contact.
jkcizbck
18:56:41 06/29/08
Pull the connector and clean it as well as check if the -
Audioquest
18:58:57 06/29/08
will definitely try that, thanks (n/m)
jkcizbck
19:06:38 06/29/08
Loose connection, squeeze the spade together a bit. (n/m)
Marc (NJ)
21:43:11 06/29/08
Re: Coolant temp gauge needle moves erratically.
90coupeconversion
22:12:22 06/30/08
